PowerTrac 1250 0200 SRT LA, with SBN Ball Nut, Double Circuit
Inch Ball Screw AssemblyStandard Accuracy Rolled Inch Ball Screw, SRT, 1.250" Ball Circle Diameter, 0.200" Lead, LH Thread, Inch Ball Nut, for SRT, Standard Accuracy, No Preload, SBN, Standard, Double Circuit
Nook ball screw and nut assemblies provide ease of application, as all that is required is installation. Nook assemblies offer turn key solutions that only require a power source (hand operation or motor). All of the elements are available for quick delivery from shelf stock.
Part Number 12500200srtla_sbndouble58b93f0
12 ft. Part Number SRT1221
16 ft. Part Number SRT1225
20 ft. Part Number No
2 ft. Part Number No
4 ft. Part Number SRT1223
6 ft. Part Number No
8 ft. Part Number SRT1227
Ball Nut Number SBN10189
Company Nook Industries
Dynamic Load [lb] 3336
End Code for Type 4 [* Journals may show tracings of the thread] 16
End Code for Types 1,2,3,5 [* Journals may show tracings of the thread] 25
Flange Part Number FLG8283
Lead Accuracy +/- [in./ft.] 0,004
Maximum Adjustable Preload [lb] No
Nominal Ball Diameter [in] 0,125
Nut Weight [lb] 1,8
Precision SRT
Screw Code 12500200 SRT LA
Screw Material 4150
Static Load [lb] 34688
Torque to Raise 1 lb. [in-lb] 0,035
Wiper Kit Part Number ELASTOMER
Ball Circle Diameter [in] 1,25
Lead [in] 0,2
Root Diameter [in] 1,115
Screw Weight [lb./ft.] 3,7
Thread Direction LH
