PowerTrac 1171 0413 SRT RA, with SBN Ball Nut, Double Circuit
Inch Ball Screw AssemblyStandard Accuracy Rolled Inch Ball Screw, SRT, 1.171" Ball Circle Diameter, 0.413" Lead, RH Thread, Inch Ball Nut, for SRT, Standard Accuracy, No Preload, SBN, Standard, Double Circuit
Nook ball screw and nut assemblies provide ease of application, as all that is required is installation. Nook assemblies offer turn key solutions that only require a power source (hand operation or motor). All of the elements are available for quick delivery from shelf stock.
Part Number 11710413srtra_sbndouble58b93f0
12 ft. Part Number SRT5043
16 ft. Part Number SRT0432
20 ft. Part Number No
2 ft. Part Number No
4 ft. Part Number SRT9569
6 ft. Part Number No
8 ft. Part Number SRT5035
Ball Nut Number SBN7511
Company Nook Industries
Dynamic Load [lb] 3894
End Code for Type 4 [* Journals may show tracings of the thread] 12
End Code for Types 1,2,3,5 [* Journals may show tracings of the thread] 20
Flange Part Number FLG7572
Lead Accuracy +/- [in./ft.] 0,004
Maximum Adjustable Preload [lb] No
Nominal Ball Diameter [in] 0,281
Nut Weight [lb] 1,9
Precision SRT
Screw Code 11710413 SRT RA
Screw Material 4150
Static Load [lb] 22917
Torque to Raise 1 lb. [in-lb] 0,073
Wiper Kit Part Number WKB2653
Ball Circle Diameter [in] 1,171
Lead [in] 0,413
Root Diameter [in] 0,87
Screw Weight [lb./ft.] 2,77
Thread Direction RH
