PowerTrac 1150 0200 SRT RA, with SEL Ball Nut, Adjustable Preloaded
Inch Ball Screw AssemblyStandard Accuracy Rolled Inch Ball Screw, SRT, 1.150" Ball Circle Diameter, 0.200" Lead, RH Thread, Inch Ball Nut, for SRT, Standard Accuracy, Preloaded, Adjustable, SEL
Nook ball screw and nut assemblies provide ease of application, as all that is required is installation. Nook assemblies offer turn key solutions that only require a power source (hand operation or motor). All of the elements are available for quick delivery from shelf stock.
Part Number 11500200srtra_seladjus58b93f0c
12 ft. Part Number SRT8753
16 ft. Part Number SRT0430
20 ft. Part Number No
2 ft. Part Number No
4 ft. Part Number SRT8738
6 ft. Part Number No
8 ft. Part Number SRT8746
Ball Nut Number SEL4270
Company Nook Industries
Dynamic Load [lb] 1185
End Code for Type 4 [* Journals may show tracings of the thread] 16
End Code for Types 1,2,3,5 [* Journals may show tracings of the thread] 25
Flange Part Number FLG8283
Lead Accuracy +/- [in./ft.] 0,004
Maximum Adjustable Preload [lb] 240
Nominal Ball Diameter [in] 0,125
Nut Weight [lb] 1,34
Precision SRT
Screw Code 11500200 SRT RA
Screw Material 4150
Static Load [lb] 13090
Torque to Raise 1 lb. [in-lb] 0,035
Wiper Kit Part Number WKB2652
Ball Circle Diameter [in] 1,15
Lead [in] 0,2
Root Diameter [in] 1,015
Screw Weight [lb./ft.] 3,18
Thread Direction RH
