PowerTrac 1000 1000 SRT RA, with SBN Ball Nut, Double Circuit
Inch Ball Screw AssemblyStandard Accuracy Rolled Inch Ball Screw, SRT, 1.000" Ball Circle Diameter, 1.000" Lead, RH Thread, Inch Ball Nut, for SRT, Standard Accuracy, No Preload, SBN, Standard, Double Circuit
Nook ball screw and nut assemblies provide ease of application, as all that is required is installation. Nook assemblies offer turn key solutions that only require a power source (hand operation or motor). All of the elements are available for quick delivery from shelf stock.
Part Number 10001000srtra_sbndouble58b93f0
12 ft. Part Number SRT6830
16 ft. Part Number SRT0429
20 ft. Part Number No
2 ft. Part Number No
4 ft. Part Number SRT6814
6 ft. Part Number No
8 ft. Part Number SRT6822
Ball Nut Number SBN10461
Company Nook Industries
Dynamic Load [lb] 2142
End Code for Type 4 [* Journals may show tracings of the thread] 12
End Code for Types 1,2,3,5 [* Journals may show tracings of the thread] 20
Flange Part Number FLG7571
Lead Accuracy +/- [in./ft.] 0,004
Maximum Adjustable Preload [lb] No
Nominal Ball Diameter [in] 0,156
Nut Weight [lb] 1,11
Precision SRT
Screw Code 10001000 SRT RA
Screw Material 4150
Static Load [lb] 11925
Torque to Raise 1 lb. [in-lb] 0,177
Wiper Kit Part Number WKB1050
Ball Circle Diameter [in] 1
Lead [in] 1
Root Diameter [in] 0,82
Screw Weight [lb./ft.] 2,2
Thread Direction RH
