PowerTrac 1000 0500 SRT RA, with SEL Ball Nut, Adjustable Preloaded
Inch Ball Screw AssemblyStandard Accuracy Rolled Inch Ball Screw, SRT, 1.000" Ball Circle Diameter, 0.500" Lead, RH Thread, Inch Ball Nut, for SRT, Standard Accuracy, Preloaded, Adjustable, SEL, Integral
Nook ball screw and nut assemblies provide ease of application, as all that is required is installation. Nook assemblies offer turn key solutions that only require a power source (hand operation or motor). All of the elements are available for quick delivery from shelf stock.
Part Number 10000500srtra_seladjus58b93f0c
12 ft. Part Number SRT9992
16 ft. Part Number SRT9993
20 ft. Part Number No
2 ft. Part Number No
4 ft. Part Number SRT9990
6 ft. Part Number No
8 ft. Part Number SRT9991
Ball Nut Number SEL10066
Company Nook Industries
Dynamic Load [lb] 3440
End Code for Type 4 [* Journals may show tracings of the thread] 12
End Code for Types 1,2,3,5 [* Journals may show tracings of the thread] 20
Flange Part Number FLG7571
Lead Accuracy +/- [in./ft.] 0,004
Maximum Adjustable Preload [lb] 817
Nominal Ball Diameter [in] 0,156
Nut Weight [lb] 2,6
Precision SRT
Screw Code 10000500 SRT RA
Screw Material 4150
Static Load [lb] 25250
Torque to Raise 1 lb. [in-lb] 0,088
Wiper Kit Part Number WKB1050
Ball Circle Diameter [in] 1
Lead [in] 0,5
Root Diameter [in] 0,82
Screw Weight [lb./ft.] 2,2
Thread Direction RH
