PowerTrac 1000 - 0250 XPR RA, with SSN Ball Nut, Preloaded, Flanged
Inch Ball Screw AssemblyPrecision Rolled Inch Ball Screw, XPR, 1.000" Ball Circle Diameter, 0.250" Lead, RH Thread, Inch Ball Nut, for XPR, Ground Accuracy, Preloaded, Fixed, SSN
To obtain optimum performance of Nook precision ball screws, it is required that the ball screws machined in their case hardened state. When annealing is applied to the end of the ball screw for machining purposes, the lead accuracy is distorted causing the ball nut to lock or jam on the ball screw.
Nook precision ball screw and nut assemblies provide ease of application without the need to machine or anneal the ball screw, as all that is required is installation. Nook precision assemblies offer turnkey solutions that only require a power source (hand operation or motor). All of the elements are available for quick delivery from shelf stock.
Part Number 1000_0250_xpr_ssn_fl
12 ft. Part Number XPR10025R144
4 ft. Part Number No
6 ft. Part Number XPR10025R72
8 ft. Part Number No
Ball Nut Number SSN10570
Company Nook Industries
Dynamic Load [lb] 2285
End Code for Type 4 [* Journals may show tracings of the thread] 12
End Code for Types 1,2,3,5 [* Journals may show tracings of the thread] 20
Flange Part Number INTEGRAL
Lead Accuracy +/- [in./ft.] 0,001
Maximum Adjustable Preload [lb] No
Nominal Ball Diameter [in] 0,156
Nut Weight [lb] 2
Precision XPR
Screw Code 1000-0250 XPR RA
Screw Material 4150
Spring Rate x 106 [lb./in.] 3,5
Static Load [lb] 15815
Torque to Raise 1 lb. [in-lb] 0,044
Wiper Kit Part Number ELASTOMER
Ball Circle Diameter [in] 1
Lead [in] 0,25
Root Diameter [in] 0,82
Screw Weight [lb./ft.] 2,2
Thread Direction RH
