PowerTrac 1000 0250 SRT RA, with SBN Ball Nut, Stainless Steel, Single Circuit
Inch Ball Screw AssemblyStandard Accuracy Rolled Inch Ball Screw, SRT, 1.000" Ball Circle Diameter, 0.250" Lead, RH Thread, Stainless Steel, Inch Ball Nut, for SRT, Standard Accuracy, No Preload, SBN, Stainless Steel
Nook ball screw and nut assemblies provide ease of application, as all that is required is installation. Nook assemblies offer turn key solutions that only require a power source (hand operation or motor). All of the elements are available for quick delivery from shelf stock.
Part Number 10000250srtra_sbnstainlessstee
12 ft. Part Number SRT6684
16 ft. Part Number No
20 ft. Part Number No
2 ft. Part Number No
4 ft. Part Number SRT6668
8 ft. Part Number SRT6676
Ball Nut Number SBN10470
Company Nook Industries
Dynamic Load [lb] 290
End Code for Type 4 [* Journals may show tracings of the thread] 12
End Code for Types 1,2,3,5 [* Journals may show tracings of the thread] 20
Flange Part Number No
Lead Accuracy +/- [in./ft.] 0,004
Maximum Adjustable Preload [lb] No
Nominal Ball Diameter [in] 0,156
Nut Weight [lb] 0,8
Precision SRT
Screw Code 10000250 SRT RS
Screw Material 174 PH Stainless
Static Load [lb] 2504
Torque to Raise 1 lb. [in-lb] 0,044
Wiper Kit Part Number WKB1050
Ball Circle Diameter [in] 1
Lead [in] 0,25
Root Diameter [in] 0,82
Screw Weight [lb./ft.] 2,2
Thread Direction RH
