PowerTrac 1000 0250 SRT RA, with SAR Ball Nut, Adjustable Preloaded, Flanged
Inch Ball Screw AssemblyStandard Accuracy Rolled Inch Ball Screw, SRT, 1.000" Ball Circle Diameter, 0.250" Lead, RH Thread, Inch Ball Nut, for SRT, Standard Accuracy, Preloaded, Adjustable, SAR, Flanged
Nook ball screw and nut assemblies provide ease of application, as all that is required is installation. Nook assemblies offer turn key solutions that only require a power source (hand operation or motor). All of the elements are available for quick delivery from shelf stock.
Part Number 10000250srtra_saradjus_flanged
12 ft. Part Number SRT5021
16 ft. Part Number SRT0426
20 ft. Part Number No
2 ft. Part Number No
4 ft. Part Number SRT5005
6 ft. Part Number No
8 ft. Part Number SRT5013
Ball Nut Number SAR3041
Company Nook Industries
Dynamic Load [lb] 1612
End Code for Type 4 [* Journals may show tracings of the thread] 12
End Code for Types 1,2,3,5 [* Journals may show tracings of the thread] 20
Flange Part Number INTEGRAL
Lead Accuracy +/- [in./ft.] 0,004
Maximum Adjustable Preload [lb] 330
Nominal Ball Diameter [in] 0,156
Nut Weight [lb] 2
Precision SRT
Screw Code 10000250 SRT RA
Screw Material 4150
Static Load [lb] 13913
Torque to Raise 1 lb. [in-lb] 0,044
Wiper Kit Part Number No
Ball Circle Diameter [in] 1
Lead [in] 0,25
Root Diameter [in] 0,82
Screw Weight [lb./ft.] 2,2
Thread Direction RH
