PowerTrac 1000 0250 SRT LA, with SBN Ball Nut, Double Circuit, Flanged
Inch Ball Screw AssemblyStandard Accuracy Rolled Inch Ball Screw, SRT, 1.000" Ball Circle Diameter, 0.250" Lead, LH Thread, Inch Ball Nut, for SRT, Standard Accuracy, No Preload, SBN, Standard, Flanged
Nook ball screw and nut assemblies provide ease of application, as all that is required is installation. Nook assemblies offer turn key solutions that only require a power source (hand operation or motor). All of the elements are available for quick delivery from shelf stock.
Part Number 10000250srtla_sbndouble_flange
12 ft. Part Number SRT5515
16 ft. Part Number SRT0428
20 ft. Part Number No
2 ft. Part Number No
4 ft. Part Number SRT5499
6 ft. Part Number No
8 ft. Part Number SRT5507
Ball Nut Number SBN8284
Company Nook Industries
Dynamic Load [lb] 3224
End Code for Type 4 [* Journals may show tracings of the thread] 12
End Code for Types 1,2,3,5 [* Journals may show tracings of the thread] 20
Flange Part Number INTEGRAL
Lead Accuracy +/- [in./ft.] 0,004
Maximum Adjustable Preload [lb] No
Nominal Ball Diameter [in] 0,156
Nut Weight [lb] 1,5
Precision SRT
Screw Code 10000250 SRT LA
Screw Material 4150
Static Load [lb] 27826
Torque to Raise 1 lb. [in-lb] 0,044
Wiper Kit Part Number WKB2651
Ball Circle Diameter [in] 1
Lead [in] 0,25
Root Diameter [in] 0,82
Screw Weight [lb./ft.] 2,2
Thread Direction LH
