PowerTrac 0750 0200 SRT RA, with SEL Ball Nut, Adjustable Preloaded
Inch Ball Screw AssemblyStandard Accuracy Rolled Inch Ball Screw, SRT, 0.750" Ball Circle Diameter, 0.200" Lead, RH Thread, Inch Ball Nut, for SRT, Standard Accuracy, Preloaded, Adjustable, SEL
Nook ball screw and nut assemblies provide ease of application, as all that is required is installation. Nook assemblies offer turn key solutions that only require a power source (hand operation or motor). All of the elements are available for quick delivery from shelf stock.
Part Number 07500200srtra_seladjus58b93f0c
12 ft. Part Number SRT7244
16 ft. Part Number No
20 ft. Part Number No
2 ft. Part Number No
4 ft. Part Number SRT7248
8 ft. Part Number SRT7296
Ball Nut Number SEL10057
Company Nook Industries
Dynamic Load [lb] 2200
End Code for Type 4 [* Journals may show tracings of the thread] 8
End Code for Types 1,2,3,5 [* Journals may show tracings of the thread] 15
Flange Part Number FLG7555
Lead Accuracy +/- [in./ft.] 0,004
Maximum Adjustable Preload [lb] 660
Nominal Ball Diameter [in] 0,141
Nut Weight [lb] 2,1
Precision SRT
Screw Code 07500200 SRT RA
Screw Material 4150
Static Load [lb] 17138
Torque to Raise 1 lb. [in-lb] 0,035
Wiper Kit Part Number WKB7200
Ball Circle Diameter [in] 0,75
Lead [in] 0,2
Root Diameter [in] 0,602
Screw Weight [lb./ft.] 1,22
Thread Direction RH
