PowerTrac 0631 1000 SRT RA, with SBN Ball Nut, Double Circuit
Inch Ball Screw AssemblyStandard Accuracy Rolled Inch Ball Screw, SRT, 0.631" Ball Circle Diameter, 1.000" Lead, RH Thread, Inch Ball Nut, for SRT, Standard Accuracy, No Preload, SBN, Standard, Double Circuit
Nook ball screw and nut assemblies provide ease of application, as all that is required is installation. Nook assemblies offer turn key solutions that only require a power source (hand operation or motor). All of the elements are available for quick delivery from shelf stock.
Part Number 06311000srtra_sbndouble58b93f0
12 ft. Part Number No
16 ft. Part Number No
20 ft. Part Number No
2 ft. Part Number SRT6124
4 ft. Part Number SRT6148
6 ft. Part Number SRT6172
8 ft. Part Number No
Ball Nut Number SBN10392
Company Nook Industries
Dynamic Load [lb] 620
End Code for Type 4 [* Journals may show tracings of the thread] 8
End Code for Types 1,2,3,5 [* Journals may show tracings of the thread] 12
Flange Part Number FLG7570
Lead Accuracy +/- [in./ft.] 0,004
Maximum Adjustable Preload [lb] No
Nominal Ball Diameter [in] 0,125
Nut Weight [lb] 0,28
Precision SRT
Screw Code 06311000 SRT RA
Screw Material 4150
Static Load [lb] 2580
Torque to Raise 1 lb. [in-lb] 0,177
Wiper Kit Part Number No
Ball Circle Diameter [in] 0,631
Lead [in] 1
Root Diameter [in] 0,5
Screw Weight [lb./ft.] 0,82
Thread Direction RH
