PowerTrac 0631 - 0200 XPR RA, with SSN Ball Nut, Preloaded, Flanged
Inch Ball Screw AssemblyPrecision Rolled Inch Ball Screw, XPR, 0.631" Ball Circle Diameter, 0.200" Lead, RH Thread, Inch Ball Nut, for SGT and XPR, Ground Accuracy, Preloaded, Fixed, SSN, Flanged
To obtain optimum performance of Nook precision ball screws, it is required that the ball screws machined in their case hardened state. When annealing is applied to the end of the ball screw for machining purposes, the lead accuracy is distorted causing the ball nut to lock or jam on the ball screw.
Nook precision ball screw and nut assemblies provide ease of application without the need to machine or anneal the ball screw, as all that is required is installation. Nook precision assemblies offer turnkey solutions that only require a power source (hand operation or motor). All of the elements are available for quick delivery from shelf stock.
Part Number 0631_0200_xpr_ssn_fl
12 ft. Part Number No
4 ft. Part Number XPR6320R48
6 ft. Part Number XPR6320R72
8 ft. Part Number No
Ball Nut Number SSN0389
Company Nook Industries
Dynamic Load [lb] 440
End Code for Type 4 [* Journals may show tracings of the thread] 8
End Code for Types 1,2,3,5 [* Journals may show tracings of the thread] 12
Flange Part Number INTEGRAL
Lead Accuracy +/- [in./ft.] 0,001
Maximum Adjustable Preload [lb] No
Nominal Ball Diameter [in] 0,125
Nut Weight [lb] 1,2
Precision XPR
Screw Code 0631-0200 XPR RA
Screw Material 4150
Spring Rate x 106 [lb./in.] 1,6
Static Load [lb] 2110
Torque to Raise 1 lb. [in-lb] 0,035
Wiper Kit Part Number ELASTOMER
Ball Circle Diameter [in] 0,631
Lead [in] 0,2
Root Diameter [in] 0,5
Screw Weight [lb./ft.] 0,86
Thread Direction RH
