PowerTrac 0631 - 0200 SRT TA, with SBN Ball Nuts, Internal Return
Inch Twin-Lead Ball Screw Assembly, Standard Accuracy Rolled, SRT, 0.631" Ball Circle Diameter, 0.200" Lead, RH/LH Thread, No Preload, SBN, Internal Return
Twin-Lead ball screw assemblies can be assembled with Nook, PowerTrac™ ball nuts, flanges and EZZE-MOUNT™ bearing supports to form cost effective systems. Twin-lead ball screws can be used in molding machines, packaging equipment, food processing machinery, robotics, material handling equipment, tire manufacturing and assembly applications.
Part Number 0631_0200_sbn_int
A [In] No
Ball Nut Number SBN10566
Company Nook Industries
Dynamic Load [lb] 712
End Code for Type 4 [* Journals may show tracings of the thread] 8
End Code for Types 1,2,3,5 [* Journals may show tracings of the thread] 12
Flange Part Number FLG7570
Incomplete Overlapping Thread Length [in] 02.50
Lead Accuracy +/- [in./ft.] 0,004
Maximum Adjustable Preload [lb] No
Maximum Overall Length [in] 72
Maximum Useable LH & RH Thread [in] 34,75
Nominal Ball Diameter [in] 0,125
Nut Weight [lb] 0,27
Precision SRT
Screw Code 0631-0200 SRT TA
Screw Material 4150
Static Load [lb] 5250
Torque to Raise 1 lb. [in-lb] 0,035
Wiper Kit Felt Part Number No
Wiper Kit Part Number WKB10407
Ball Circle Diameter [in] 0,631
Lead [in] 0,2
Root Diameter [in] 0,5
Screw Weight [lb./ft.] 0,82
Thread Direction RH
