PowerTrac 0631 0200 SRT RA, with SBN Ball Nut, Stainless Steel, Single Circuit
Inch Ball Screw AssemblyStandard Accuracy Rolled Inch Ball Screw, SRT, 0.631" Ball Circle Diameter, 0.200" Lead, RH Thread, Stainless Steel, Inch Ball Nut, for SRT, Standard Accuracy, No Preload, SBN, Stainless Steel, Single Circuit
Nook ball screw and nut assemblies provide ease of application, as all that is required is installation. Nook assemblies offer turn key solutions that only require a power source (hand operation or motor). All of the elements are available for quick delivery from shelf stock.
Part Number 06310200srtra_sbnstainlessstee
12 ft. Part Number No
16 ft. Part Number No
20 ft. Part Number No
2 ft. Part Number SRT5359
4 ft. Part Number SRT5648
6 ft. Part Number SRT5378
8 ft. Part Number No
Ball Nut Number SBN7645
Company Nook Industries
Dynamic Load [lb] 140
End Code for Type 4 [* Journals may show tracings of the thread] 8
End Code for Types 1,2,3,5 [* Journals may show tracings of the thread] 12
Flange Part Number No
Lead Accuracy +/- [in./ft.] 0,004
Maximum Adjustable Preload [lb] No
Nominal Ball Diameter [in] 0,125
Nut Weight [lb] 0,27
Precision SRT
Screw Code 06310200 SRT RS
Screw Material 174 PH Stainless
Static Load [lb] 1149
Torque to Raise 1 lb. [in-lb] 0,035
Wiper Kit Part Number No
Ball Circle Diameter [in] 0,631
Lead [in] 0,2
Root Diameter [in] 0,5
Screw Weight [lb./ft.] 0,82
Thread Direction RH
