PowerTrac 0631 0200 SRT RA, with SBN Ball Nut, Single Circuit, Safety Thread
Inch Ball Screw AssemblyStandard Accuracy Rolled Inch Ball Screw, SRT, 0.631" Ball Circle Diameter, 0.200" Lead, RH Thread, Inch Ball Nut, for SRT, Standard Accuracy, No Preload, SBN, Standard, Single Circuit, Safety Thread
Nook ball screw and nut assemblies provide ease of application, as all that is required is installation. Nook assemblies offer turn key solutions that only require a power source (hand operation or motor). All of the elements are available for quick delivery from shelf stock.
Part Number 06310200srtra_sbns_safetythrea
12 ft. Part Number No
16 ft. Part Number No
20 ft. Part Number No
2 ft. Part Number SRT9392
4 ft. Part Number SRT9987
6 ft. Part Number SRT7540
8 ft. Part Number No
Ball Nut Number SBN10583
Company Nook Industries
Dynamic Load [lb] 815
End Code for Type 4 [* Journals may show tracings of the thread] 8
End Code for Types 1,2,3,5 [* Journals may show tracings of the thread] 12
Flange Part Number FLG7570
Lead Accuracy +/- [in./ft.] 0,004
Maximum Adjustable Preload [lb] No
Nominal Ball Diameter [in] 0,125
Nut Weight [lb] 0,27
Precision SRT
Screw Code 06310200 SRT RA
Screw Material 4150
Static Load [lb] 6384
Torque to Raise 1 lb. [in-lb] 0,035
Wiper Kit Part Number WKB10407
Ball Circle Diameter [in] 0,631
Lead [in] 0,2
Root Diameter [in] 0,5
Screw Weight [lb./ft.] 0,82
Thread Direction RH
