PowerTrac 0500 0500 SRT RA, with SBN Ball Nut, Nickel Plated, Double Circuit
Inch Ball Screw AssemblyStandard Accuracy Rolled Inch Ball Screw, SRT, 0.500" Ball Circle Diameter, 0.500" Lead, RH Thread, Stainless Steel, Inch Ball Nut, for SRT, Standard Accuracy, No Preload, SBN, Nickel Plated, Double Circuit
Nook ball screw and nut assemblies provide ease of application, as all that is required is installation. Nook assemblies offer turn key solutions that only require a power source (hand operation or motor). All of the elements are available for quick delivery from shelf stock.
Part Number 05000500srtra_sbnnickelplated
12 ft. Part Number No
16 ft. Part Number No
20 ft. Part Number No
2 ft. Part Number SRT6700
4 ft. Part Number SRT6704
6 ft. Part Number SRT6846
8 ft. Part Number No
Ball Nut Number SBN9582E
Company Nook Industries
Dynamic Load [lb] 786
End Code for Type 4 [* Journals may show tracings of the thread] 6
End Code for Types 1,2,3,5 [* Journals may show tracings of the thread] 8
Flange Part Number FLG7570
Lead Accuracy +/- [in./ft.] 0,004
Maximum Adjustable Preload [lb] No
Nominal Ball Diameter [in] 0,125
Nut Weight [lb] 0,27
Precision SRT
Screw Code 05000500 SRT RS
Screw Material 174 PH Stainless
Static Load [lb] 4131
Torque to Raise 1 lb. [in-lb] 0,088
Wiper Kit Part Number No
Ball Circle Diameter [in] 0,5
Lead [in] 0,5
Root Diameter [in] 0,36
Screw Weight [lb./ft.] 0,5
Thread Direction RH
