PowerTrac 0375 - 0125 SRT TA, with SBN Ball Nuts, Single Circuit
Inch Twin-Lead Ball Screw Assembly, Standard Accuracy Rolled, SRT, 0.375" Ball Circle Diameter, 0.125" Lead, RH/LH Thread, No Preload, SBN, Single Circuit
Twin-Lead ball screw assemblies can be assembled with Nook, PowerTrac™ ball nuts, flanges and EZZE-MOUNT™ bearing supports to form cost effective systems. Twin-lead ball screws can be used in molding machines, packaging equipment, food processing machinery, robotics, material handling equipment, tire manufacturing and assembly applications.
Part Number 0375_0125_sbn_s
A [In] No
Ball Nut Number SBN9574
Company Nook Industries
Dynamic Load [lb] 136
End Code for Type 4 [* Journals may show tracings of the thread] 4
End Code for Types 1,2,3,5 [* Journals may show tracings of the thread] 7
Flange Part Number FLG6751
Incomplete Overlapping Thread Length [in] 02
Lead Accuracy +/- [in./ft.] 0,004
Maximum Adjustable Preload [lb] No
Maximum Overall Length [in] 36
Maximum Useable LH & RH Thread [in] 17
Nominal Ball Diameter [in] 0,063
Nut Weight [lb] 0,13
Precision SRT
Screw Code 0375-0125 SRT TA
Screw Material 4150
Static Load [lb] 1415
Torque to Raise 1 lb. [in-lb] 0,022
Wiper Kit Felt Part Number No
Wiper Kit Part Number -0
Ball Circle Diameter [in] 0,375
Lead [in] 0,125
Root Diameter [in] 0,3
Screw Weight [lb./ft.] 0,31
Thread Direction RH
