PowerTrac 0375 0125 SRT RA, with SEL Ball Nut, Adjustable Preloaded
Inch Ball Screw AssemblyStandard Accuracy Rolled Inch Ball Screw, SRT, 0.375" Ball Circle Diameter, 0.125" Lead, RH Thread, Inch Ball Nut, for SRT, Standard Accuracy, Preloaded, Adjustable, SEL
Nook ball screw and nut assemblies provide ease of application, as all that is required is installation. Nook assemblies offer turn key solutions that only require a power source (hand operation or motor). All of the elements are available for quick delivery from shelf stock.
Part Number 03750125srtra_seladjus58b93f0c
12 ft. Part Number No
16 ft. Part Number No
20 ft. Part Number No
2 ft. Part Number SRT9420
4 ft. Part Number SRT7538
8 ft. Part Number No
Ball Nut Number SEL0375
Company Nook Industries
Dynamic Load [lb] 136
End Code for Type 4 [* Journals may show tracings of the thread] 4
End Code for Types 1,2,3,5 [* Journals may show tracings of the thread] 7
Flange Part Number FLG6751
Lead Accuracy +/- [in./ft.] 0,004
Maximum Adjustable Preload [lb] 10
Nominal Ball Diameter [in] 0,063
Nut Weight [lb] 0,21
Precision SRT
Screw Code 03750125 SRT RA
Screw Material 4150
Static Load [lb] 1415
Torque to Raise 1 lb. [in-lb] 0,022
Wiper Kit Part Number No
Ball Circle Diameter [in] 0,375
Lead [in] 0,125
Root Diameter [in] 0,3
Screw Weight [lb./ft.] 0,31
Thread Direction RH
