PowerTrac 0375 0125 SRT RA, with SBN Ball Nut, Stainless Steel, Single Circuit
Inch Ball Screw AssemblyStandard Accuracy Rolled Inch Ball Screw, SRT, 0.375" Ball Circle Diameter, 0.125" Lead, RH Thread, Stainless Steel, Inch Ball Nut, for SRT, Standard Accuracy, No Preload, SBN, Stainless Steel, Single Circuit
Nook ball screw and nut assemblies provide ease of application, as all that is required is installation. Nook assemblies offer turn key solutions that only require a power source (hand operation or motor). All of the elements are available for quick delivery from shelf stock.
Part Number 03750125srtra_sbnstainlessstee
12 ft. Part Number No
16 ft. Part Number No
20 ft. Part Number No
2 ft. Part Number SRT6536
4 ft. Part Number SRT6540
8 ft. Part Number No
Ball Nut Number SBN9578
Company Nook Industries
Dynamic Load [lb] 24
End Code for Type 4 [* Journals may show tracings of the thread] 4
End Code for Types 1,2,3,5 [* Journals may show tracings of the thread] 7
Flange Part Number No
Lead Accuracy +/- [in./ft.] 0,004
Maximum Adjustable Preload [lb] No
Nominal Ball Diameter [in] 0,063
Nut Weight [lb] 0,13
Precision SRT
Screw Code 03750125 SRT RS
Screw Material 174 PH Stainless
Static Load [lb] 255
Torque to Raise 1 lb. [in-lb] 0,022
Wiper Kit Part Number No
Ball Circle Diameter [in] 0,375
Lead [in] 0,125
Root Diameter [in] 0,3
Screw Weight [lb./ft.] 0,31
Thread Direction RH
