PowerTrac 0375 0125 SRT LA, with SBN Ball Nut, Single Circuit
Inch Ball Screw AssemblyStandard Accuracy Rolled Inch Ball Screw, SRT, 0.375" Ball Circle Diameter, 0.125" Lead, LH Thread, Inch Ball Nut, for SRT, Standard Accuracy, No Preload, SBN, Standard, Single Circuit
Nook ball screw and nut assemblies provide ease of application, as all that is required is installation. Nook assemblies offer turn key solutions that only require a power source (hand operation or motor). All of the elements are available for quick delivery from shelf stock.
Part Number 03750125srtla_sbns58b93f0c19e1
12 ft. Part Number No
16 ft. Part Number No
20 ft. Part Number No
2 ft. Part Number SRT8528
4 ft. Part Number SRT8532
8 ft. Part Number No
Ball Nut Number SBN9576
Company Nook Industries
Dynamic Load [lb] 136
End Code for Type 4 [* Journals may show tracings of the thread] 4
End Code for Types 1,2,3,5 [* Journals may show tracings of the thread] 7
Flange Part Number FLG6751
Lead Accuracy +/- [in./ft.] 0,004
Maximum Adjustable Preload [lb] No
Nominal Ball Diameter [in] 0,063
Nut Weight [lb] 0,13
Precision SRT
Screw Code 03750125 SRT LA
Screw Material 4150
Static Load [lb] 1415
Torque to Raise 1 lb. [in-lb] 0,022
Wiper Kit Part Number No
Ball Circle Diameter [in] 0,375
Lead [in] 0,125
Root Diameter [in] 0,3
Screw Weight [lb./ft.] 0,31
Thread Direction LH
