PowerAC 6"-1 1/2 RA w/Bronze Nut, with Integral Flange
Inch Acme Screw Assembly, 6", 4140, 1.5 Turns Per Inch, RH, 1 Starts, Bronze Nut, Integral Flange
Nook Industries Offers the largest selections of rolled amce screw sizes in the industry. Rolled thread screws are cost effective and are stocked for quick delivery.
PowerAcâ„¢ Inch Acme screws and nuts include a centralizing (C) thread form to prevent wedging and binding. When compared to general-purpose thread forms (G), centralizing threads are manufactured with tighter tolerances and reduced clearance on the major diameter.
Special high tensile bronze is selected for our smooth running, anti-wedging bronze nuts.
  • Material: Nook Bronze
  • Tensile Yield: 50,000 psi
  • Tensile Ultimate: 65,000 psi
  • Hardness: HB75
  • Dynamic co-efficient of friction: 0.125 with Nook Lubricant
Part Number powerac_6_1_1_2_w_bronze_nut
20 ft. Part Number 10602
3 ft. Part Number No
6 ft. Part Number 12602
A - Root Diameter Minimum [in] No
B [in] 7
C [in] 8
Company Nook Industries
D - Nominal Rod Diameter [in] 6
Dynamic Load Capacity [lb] 180000
E [in] 2
End Code for Type 4 [* Journals may show tracings of the thread] n/a
End Code for Types 1,2,3,5 [* Journals may show tracings of the thread] n/a
F BCD [in] 12
F (n) Dia. [in] (6) 1.125
Flange No-Lash Part Number n/a
Flange Part Number n/a
Flange Weight [lb] n/a
Form 2G
G [in] 2,02
H [in] 14
J [In] 7.847-8
Lash (Maximum Axial) [in] 0,025
Nut Weight [lb] n/a
Screw Code 602-RA
Screw Material 4140 Series
Starts 1
Static Load Capacity [lb] 576000
Thread Code 602
Threads Per Inch 1,5
Torque to Raise 1 lb. [in-lb] 0,474
Turns Per Inch 1,5
12 ft. Part Number 13602
Efficiency [%] 22
Part Number 6954-1
Lead Accuracy In In 0,0006
Lead [in] 0,667
Pitch [in] 0,667
Screw Weight [lb./ft.] 87
