PowerAC 5/8"-8 LA w/Bronze Nut
Inch Acme Screw Assembly, 5/8", 4140, 8 Turns Per Inch, LH, 1 Starts, Bronze Nut
Nook Industries Offers the largest selections of rolled amce screw sizes in the industry. Rolled thread screws are cost effective and are stocked for quick delivery.
PowerAcâ„¢ Inch Acme screws and nuts include a centralizing (C) thread form to prevent wedging and binding. When compared to general-purpose thread forms (G), centralizing threads are manufactured with tighter tolerances and reduced clearance on the major diameter.
Special high tensile bronze is selected for our smooth running, anti-wedging bronze nuts.
  • Material: Nook Bronze
  • Tensile Yield: 50,000 psi
  • Tensile Ultimate: 65,000 psi
  • Hardness: HB75
  • Dynamic co-efficient of friction: 0.125 with Nook Lubricant
Part Number powerac_5_8_8_la_w_bronze_nut
20 ft. Part Number No
3 ft. Part Number 51068
6 ft. Part Number 52068
A - Root Diameter Minimum [in] 0,457
B [in] 1
C [in] 1,12
Company Nook Industries
D - Nominal Rod Diameter [in] 0,625
Dynamic Load Capacity [lb] 1953
E [in] 0,5
End Code for Type 4 [* Journals may show tracings of the thread] 6
End Code for Types 1,2,3,5 [* Journals may show tracings of the thread] 10
F BCD [in] 2,09
F (n) Dia. [in] (4) .266
Flange No-Lash Part Number No
Flange Part Number FLG7570
Flange Weight [lb] 0,77
Form 2C
G [in] 0,53
H [in] 2,6
J [In] .937-16
Lash (Maximum Axial) [in] 0,008
Nut Weight [lb] 0,22
Screw Code 068-LA
Screw Material 4140 Series
Starts 1
Static Load Capacity [lb] 6250
Thread Code 68
Threads Per Inch 8
Torque to Raise 1 lb. [in-lb] 0,058
Turns Per Inch 8
12 ft. Part Number 53068
Efficiency [%] 34
Part Number 80068
Lead Accuracy In In 0,0003
Lead [in] 0,125
Pitch [in] 0,125
Screw Weight [lb./ft.] 0,84
