PowerAC 5/16"-4 RS w/Plastic Nut
Inch Acme Screw Assembly, 5/16", Stainless, 4 Turns Per Inch, RH, 2 Starts, Plastic Nut
Nook Industries Offers the largest selections of rolled amce screw sizes in the industry. Rolled thread screws are cost effective and are stocked for quick delivery.
PowerAc™ Inch Acme screws and nuts include a centralizing (C) thread form to prevent wedging and binding. When compared to general-purpose thread forms (G), centralizing threads are manufactured with tighter tolerances and reduced clearance on the major diameter.
The high strength and inherent lubricity of plastic Acme and Trapezoidal nut material can result in product life that can equal or exceed conventional nut materials.
  • Tensile Strength @70°F: 8,000 psi
  • Compressive Strength @70°F: 16,000 psi
  • PV Limit: 2,700 lubricated
  • Co-efficient of friction: 0.10 lubricated
Part Number powerac_5_16_4_rs_w_plastic_n
3 ft. Part Number 91028
6 ft. Part Number 92028
A - Root Diameter Minimum [in] 0,216
B [in] 0,62
C [in] 0,68
Company Nook Industries
D - Nominal Rod Diameter [in] 0,313
Dynamic Load Capacity [lb] 205
E [in] 0,38
End Code for Type 4 [* Journals may show tracings of the thread] 2
End Code for Types 1,2,3,5 [* Journals may show tracings of the thread] 5
F BCD [in] 1,25
F (n) Dia. [in] (4) .269
Flange No-Lash Part Number No
Flange Part Number 70160
Flange Weight [lb] 0,23
Form Stub
G [in] 0,41
H [in] 1,61
J [In] .562-18
Lash (Maximum Axial) [in] 0,008
Nut Weight [lb] 0,01
Screw Code 028-RS
Screw Material 300 Series Stainless
Starts 2
Static Load Capacity [lb] 205
Thread Code 28
Threads Per Inch 8
Torque to Raise 1 lb. [in-lb] 0,054
Turns Per Inch 4
12 ft. Part Number No
Efficiency [%] 73
Part Number 30028
Lead Accuracy In In 0,0003
Lead [in] 0,25
Pitch [in] 0,125
Screw Weight [lb./ft.] 0,18
