PowerAC 5"-1 1/2 RA w/Bronze Nut
Inch Acme Screw Assembly, 5", 4140, 1.5 Turns Per Inch, RH, 1 Starts, Bronze Nut
Nook Industries Offers the largest selections of rolled amce screw sizes in the industry. Rolled thread screws are cost effective and are stocked for quick delivery.
PowerAcâ„¢ Inch Acme screws and nuts include a centralizing (C) thread form to prevent wedging and binding. When compared to general-purpose thread forms (G), centralizing threads are manufactured with tighter tolerances and reduced clearance on the major diameter.
Special high tensile bronze is selected for our smooth running, anti-wedging bronze nuts.
  • Material: Nook Bronze
  • Tensile Yield: 50,000 psi
  • Tensile Ultimate: 65,000 psi
  • Hardness: HB75
  • Dynamic co-efficient of friction: 0.125 with Nook Lubricant
Part Number powerac_5_1_1_2_w_bronze_nut
20 ft. Part Number 10552
3 ft. Part Number No
6 ft. Part Number 12552
A - Root Diameter Minimum [in] No
B [in] 7,5
C [in] 7,5
Company Nook Industries
D - Nominal Rod Diameter [in] 5
Dynamic Load Capacity [lb] 145000
E [in] 2
End Code for Type 4 [* Journals may show tracings of the thread] 67
End Code for Types 1,2,3,5 [* Journals may show tracings of the thread] 105
F BCD [in] 10
F (n) Dia. [in] (8) 1.25
Flange No-Lash Part Number 73552
Flange Part Number 75000
Flange Weight [lb] 110
Form 2G
G [in] 2,02
H [in] 12
J [In] 7.066-8
Lash (Maximum Axial) [in] 0,022
Nut Weight [lb] 60,59
Screw Code 552-RA
Screw Material 4140 Series
Starts 1
Static Load Capacity [lb] 470000
Thread Code 552
Threads Per Inch 1,5
Torque to Raise 1 lb. [in-lb] 0,398
Turns Per Inch 1,5
12 ft. Part Number 13552
Efficiency [%] 26
Part Number 20552
Lead Accuracy In In 0,0006
Lead [in] 0,667
Pitch [in] 0,667
Screw Weight [lb./ft.] 57,5
