PowerAC 3/8"-6 RS w/Plastic Nut
Inch Acme Screw Assembly, 3/8", Stainless, 6 Turns Per Inch, RH, 2 Starts, Plastic Nut
Nook Industries Offers the largest selections of rolled amce screw sizes in the industry. Rolled thread screws are cost effective and are stocked for quick delivery.
PowerAc™ Inch Acme screws and nuts include a centralizing (C) thread form to prevent wedging and binding. When compared to general-purpose thread forms (G), centralizing threads are manufactured with tighter tolerances and reduced clearance on the major diameter.
The high strength and inherent lubricity of plastic Acme and Trapezoidal nut material can result in product life that can equal or exceed conventional nut materials.
  • Tensile Strength @70°F: 8,000 psi
  • Compressive Strength @70°F: 16,000 psi
  • PV Limit: 2,700 lubricated
  • Co-efficient of friction: 0.10 lubricated
Part Number powerac_3_8_6_rs_w_plastic_nu
3 ft. Part Number 91036
6 ft. Part Number 92036
A - Root Diameter Minimum [in] 0,263
B [in] 0,62
C [in] 0,68
Company Nook Industries
D - Nominal Rod Diameter [in] 0,375
Dynamic Load Capacity [lb] 351
E [in] 0,38
End Code for Type 4 [* Journals may show tracings of the thread] 4
End Code for Types 1,2,3,5 [* Journals may show tracings of the thread] 7*
F BCD [in] 1,25
F (n) Dia. [in] (4) .270
Flange No-Lash Part Number No
Flange Part Number 70160
Flange Weight [lb] 0,23
Form 2C
G [in] 0,41
H [in] 1,61
J [In] .562-18
Lash (Maximum Axial) [in] 0,006
Nut Weight [lb] 0,01
Screw Code 036-RS
Screw Material 300 Series Stainless
Starts 2
Static Load Capacity [lb] 351
Thread Code 36
Threads Per Inch 12
Torque to Raise 1 lb. [in-lb] 0,044
Turns Per Inch 6
12 ft. Part Number No
Efficiency [%] 60
Part Number 30036
Lead Accuracy In In 0,0003
Lead [in] 0,166
Pitch [in] 0,083
Screw Weight [lb./ft.] 0,29
