PowerAC 3/8"-16 RS w/Bronze Nut
Inch Acme Screw Assembly, 3/8", Stainless, 16 Turns Per Inch, RH, 1 Starts, Bronze Nut
Nook Industries Offers the largest selections of rolled amce screw sizes in the industry. Rolled thread screws are cost effective and are stocked for quick delivery.
PowerAcâ„¢ Inch Acme screws and nuts include a centralizing (C) thread form to prevent wedging and binding. When compared to general-purpose thread forms (G), centralizing threads are manufactured with tighter tolerances and reduced clearance on the major diameter.
Special high tensile bronze is selected for our smooth running, anti-wedging bronze nuts.
  • Material: Nook Bronze
  • Tensile Yield: 50,000 psi
  • Tensile Ultimate: 65,000 psi
  • Hardness: HB75
  • Dynamic co-efficient of friction: 0.125 with Nook Lubricant
Part Number powerac_3_8_16_rs_w_bronze_nu
20 ft. Part Number No
3 ft. Part Number 91033
6 ft. Part Number 92033
A - Root Diameter Minimum [in] 0,286
B [in] 0,62
C [in] 0,68
Company Nook Industries
D - Nominal Rod Diameter [in] 0,375
Dynamic Load Capacity [lb] 703
E [in] 0,38
End Code for Type 4 [* Journals may show tracings of the thread] 4
End Code for Types 1,2,3,5 [* Journals may show tracings of the thread] 7
F BCD [in] 1,25
F (n) Dia. [in] (4) .266
Flange No-Lash Part Number No
Flange Part Number 70160
Flange Weight [lb] 0,23
Form Stub
G [in] 0,41
H [in] 1,61
J [In] .562-18
Lash (Maximum Axial) [in] 0,007
Nut Weight [lb] 0,05
Screw Code 033-RS
Screw Material 300 Series Stainless
Starts 1
Static Load Capacity [lb] 2250
Thread Code 33
Threads Per Inch 16
Torque to Raise 1 lb. [in-lb] 0,031
Turns Per Inch 16
12 ft. Part Number No
Efficiency [%] 32
Part Number 20033
Lead Accuracy In In 0,0003
Lead [in] 0,062
Pitch [in] 0,062
Screw Weight [lb./ft.] 0,29
