PowerAC 3/4"-3 LA w/Bronze Nut
Inch Acme Screw Assembly, 3/4", 4140, 3 Turns Per Inch, LH, 2 Starts, Bronze Nut
Nook Industries Offers the largest selections of rolled amce screw sizes in the industry. Rolled thread screws are cost effective and are stocked for quick delivery.
PowerAcâ„¢ Inch Acme screws and nuts include a centralizing (C) thread form to prevent wedging and binding. When compared to general-purpose thread forms (G), centralizing threads are manufactured with tighter tolerances and reduced clearance on the major diameter.
Special high tensile bronze is selected for our smooth running, anti-wedging bronze nuts.
  • Material: Nook Bronze
  • Tensile Yield: 50,000 psi
  • Tensile Ultimate: 65,000 psi
  • Hardness: HB75
  • Dynamic co-efficient of friction: 0.125 with Nook Lubricant
Part Number powerac_3_4_3_la_w_bronze_nut
20 ft. Part Number No
3 ft. Part Number 51073
6 ft. Part Number 52073
A - Root Diameter Minimum [in] 0,537
B [in] 1,25
C [in] 1,12
Company Nook Industries
D - Nominal Rod Diameter [in] 0,75
Dynamic Load Capacity [lb] 2812
E [in] 0,5
End Code for Type 4 [* Journals may show tracings of the thread] 8
End Code for Types 1,2,3,5 [* Journals may show tracings of the thread] 12
F BCD [in] 2,09
F (n) Dia. [in] (4) .266
Flange No-Lash Part Number 73262
Flange Part Number 70262
Flange Weight [lb] 0,78
Form 2C
G [in] 0,53
H [in] 2,63
J [In] 10-18
Lash (Maximum Axial) [in] 0,009
Nut Weight [lb] 0,23
Screw Code 073-LA
Screw Material 4140 Series
Starts 2
Static Load Capacity [lb] 9000
Thread Code 73
Threads Per Inch 6
Torque to Raise 1 lb. [in-lb] 0,099
Turns Per Inch 3
12 ft. Part Number 53073
Efficiency [%] 54
Part Number 80073
Lead Accuracy In In 0,0003
Lead [in] 0,333
Pitch [in] 0,167
Screw Weight [lb./ft.] 1,17
