PowerAC 2"-4 RA w/Bronze Nut
Inch Acme Screw Assembly, 2", 4140, 4 Turns Per Inch, RH, 1 Starts, Bronze Nut
Nook Industries Offers the largest selections of rolled amce screw sizes in the industry. Rolled thread screws are cost effective and are stocked for quick delivery.
PowerAcâ„¢ Inch Acme screws and nuts include a centralizing (C) thread form to prevent wedging and binding. When compared to general-purpose thread forms (G), centralizing threads are manufactured with tighter tolerances and reduced clearance on the major diameter.
Special high tensile bronze is selected for our smooth running, anti-wedging bronze nuts.
  • Material: Nook Bronze
  • Tensile Yield: 50,000 psi
  • Tensile Ultimate: 65,000 psi
  • Hardness: HB75
  • Dynamic co-efficient of friction: 0.125 with Nook Lubricant
Part Number powerac_2_4_w_bronze_nut
20 ft. Part Number No
3 ft. Part Number 11204
6 ft. Part Number 12204
A - Root Diameter Minimum [in] 1,694
B [in] 3,47
C [in] 2,75
Company Nook Industries
D - Nominal Rod Diameter [in] 2
Dynamic Load Capacity [lb] 20000
E [in] 0,88
End Code for Type 4 [* Journals may show tracings of the thread] 22
End Code for Types 1,2,3,5 [* Journals may show tracings of the thread] 40
F BCD [in] 4,062
F (n) Dia. [in] (4) .531
Flange No-Lash Part Number 73500
Flange Part Number FLG7573
Flange Weight [lb] 4,73
Form 2C
G [in] 0,9
H [in] 4,94
J [In] 2.548-18
Lash (Maximum Axial) [in] 0,012
Nut Weight [lb] 2,59
Screw Code 204-RA
Screw Material 4140 Series
Starts 1
Static Load Capacity [lb] 64000
Thread Code 204
Threads Per Inch 4
Torque to Raise 1 lb. [in-lb] 0,166
Turns Per Inch 4
12 ft. Part Number 13204
Efficiency [%] 24
Part Number 20204
Lead Accuracy In In 0,0003
Lead [in] 0,25
Pitch [in] 0,25
Screw Weight [lb./ft.] 9,28
