PowerAC 2 1/2"-3 RA w/Bronze Nut
Inch Acme Screw Assembly, 2 1/2", 4140, 3 Turns Per Inch, RH, 1 Starts, Bronze Nut
Nook Industries Offers the largest selections of rolled amce screw sizes in the industry. Rolled thread screws are cost effective and are stocked for quick delivery.
PowerAcâ„¢ Inch Acme screws and nuts include a centralizing (C) thread form to prevent wedging and binding. When compared to general-purpose thread forms (G), centralizing threads are manufactured with tighter tolerances and reduced clearance on the major diameter.
Special high tensile bronze is selected for our smooth running, anti-wedging bronze nuts.
  • Material: Nook Bronze
  • Tensile Yield: 50,000 psi
  • Tensile Ultimate: 65,000 psi
  • Hardness: HB75
  • Dynamic co-efficient of friction: 0.125 with Nook Lubricant
Part Number powerac_2_1_2_3_w_bronze_nut
20 ft. Part Number No
3 ft. Part Number 11253
6 ft. Part Number 12253
A - Root Diameter Minimum [in] 2,106
B [in] 4,25
C [in] 3,38
Company Nook Industries
D - Nominal Rod Diameter [in] 2,5
Dynamic Load Capacity [lb] 31250
E [in] 1,56
End Code for Type 4 [* Journals may show tracings of the thread] 32
End Code for Types 1,2,3,5 [* Journals may show tracings of the thread] 50
F BCD [in] 4,38
F (n) Dia. [in] (6) .656
Flange No-Lash Part Number 73540
Flange Part Number FLG7574
Flange Weight [lb] 9,88
Form 2C
G [in] 1,58
H [in] 5,38
J [In] 3.137-12
Lash (Maximum Axial) [in] 0,013
Nut Weight [lb] 5,91
Screw Code 253-RA
Screw Material 4140 Series
Starts 1
Static Load Capacity [lb] 100000
Thread Code 253
Threads Per Inch 3
Torque to Raise 1 lb. [in-lb] 0,212
Turns Per Inch 3
12 ft. Part Number 13253
Efficiency [%] 25
Part Number 20253
Lead Accuracy In In 0,0003
Lead [in] 0,333
Pitch [in] 0,333
Screw Weight [lb./ft.] 14,38
