PowerAC 1/2"-10 RS w/Plastic Nut
Inch Acme Screw Assembly, 1/2", Stainless, 10 Turns Per Inch, RH, 1 Starts, Plastic Nut
Nook Industries Offers the largest selections of rolled amce screw sizes in the industry. Rolled thread screws are cost effective and are stocked for quick delivery.
PowerAc™ Inch Acme screws and nuts include a centralizing (C) thread form to prevent wedging and binding. When compared to general-purpose thread forms (G), centralizing threads are manufactured with tighter tolerances and reduced clearance on the major diameter.
The high strength and inherent lubricity of plastic Acme and Trapezoidal nut material can result in product life that can equal or exceed conventional nut materials.
  • Tensile Strength @70°F: 8,000 psi
  • Compressive Strength @70°F: 16,000 psi
  • PV Limit: 2,700 lubricated
  • Co-efficient of friction: 0.10 lubricated
Part Number powerac_1_2_10_rs_w_plastic_n
3 ft. Part Number 91050
6 ft. Part Number 92050
A - Root Diameter Minimum [in] 0,359
B [in] 0,75
C [in] 1,12
Company Nook Industries
D - Nominal Rod Diameter [in] 0,5
Dynamic Load Capacity [lb] 625
E [in] 0,5
End Code for Type 4 [* Journals may show tracings of the thread] 6*
End Code for Types 1,2,3,5 [* Journals may show tracings of the thread] 9
F BCD [in] 2,09
F (n) Dia. [in] (4) .266
Flange No-Lash Part Number No
Flange Part Number FLG7570
Flange Weight [lb] 0,77
Form 2C
G [in] 0,53
H [in] 2,6
J [In] .937-16
Lash (Maximum Axial) [in] 0,007
Nut Weight [lb] 0,03
Screw Code 050-RS
Screw Material 300 Series Stainless
Starts 1
Static Load Capacity [lb] 625
Thread Code 50
Threads Per Inch 10
Torque to Raise 1 lb. [in-lb] 0,039
Turns Per Inch 10
12 ft. Part Number 93050
Efficiency [%] 40
Part Number 30050
Lead Accuracy In In 0,0003
Lead [in] 0,1
Pitch [in] 0,1
Screw Weight [lb./ft.] 0,53
