PowerAC 1 1/4"-5 LS w/Plastic Nut
Inch Acme Screw Assembly, 1 1/4", Stainless, 5 Turns Per Inch, LH, 1 Starts, Plastic Nut
Nook Industries Offers the largest selections of rolled amce screw sizes in the industry. Rolled thread screws are cost effective and are stocked for quick delivery.
PowerAc™ Inch Acme screws and nuts include a centralizing (C) thread form to prevent wedging and binding. When compared to general-purpose thread forms (G), centralizing threads are manufactured with tighter tolerances and reduced clearance on the major diameter.
The high strength and inherent lubricity of plastic Acme and Trapezoidal nut material can result in product life that can equal or exceed conventional nut materials.
  • Tensile Strength @70°F: 8,000 psi
  • Compressive Strength @70°F: 16,000 psi
  • PV Limit: 2,700 lubricated
  • Co-efficient of friction: 0.10 lubricated
Part Number powerac_1_1_4_5_ls_w_plastic
3 ft. Part Number 94125
6 ft. Part Number 95125
A - Root Diameter Minimum [in] 0,999
B [in] 1,75
C [in] 2,12
Company Nook Industries
D - Nominal Rod Diameter [in] 1,25
Dynamic Load Capacity [lb] 3906
E [in] 0,81
End Code for Type 4 [* Journals may show tracings of the thread] 16
End Code for Types 1,2,3,5 [* Journals may show tracings of the thread] 25
F BCD [in] 3,44
F (n) Dia. [in] (4) .397
Flange No-Lash Part Number 73420
Flange Part Number FLG7572
Flange Weight [lb] 3,19
Form 2C
G [in] 0,83
H [in] 4,2
J [In] 1.967-18
Lash (Maximum Axial) [in] 0,01
Nut Weight [lb] 0,19
Screw Code 125-LS
Screw Material 300 Series Stainless
Starts 1
Static Load Capacity [lb] 3906
Thread Code 125
Threads Per Inch 5
Torque to Raise 1 lb. [in-lb] 0,092
Turns Per Inch 5
12 ft. Part Number 96125
Efficiency [%] 35
Part Number 40125
Lead Accuracy In In 0,0003
Lead [in] 0,2
Pitch [in] 0,2
Screw Weight [lb./ft.] 3,49
