PowerAC 1 1/2"-10 LA w/Bronze Nut
Inch Acme Screw Assembly, 1 1/2", 4140, 10 Turns Per Inch, LH, 1 Starts, Bronze Nut
Nook Industries Offers the largest selections of rolled amce screw sizes in the industry. Rolled thread screws are cost effective and are stocked for quick delivery.
PowerAcâ„¢ Inch Acme screws and nuts include a centralizing (C) thread form to prevent wedging and binding. When compared to general-purpose thread forms (G), centralizing threads are manufactured with tighter tolerances and reduced clearance on the major diameter.
Special high tensile bronze is selected for our smooth running, anti-wedging bronze nuts.
  • Material: Nook Bronze
  • Tensile Yield: 50,000 psi
  • Tensile Ultimate: 65,000 psi
  • Hardness: HB75
  • Dynamic co-efficient of friction: 0.125 with Nook Lubricant
Part Number powerac_1_1_2_10_la_w_bronze
20 ft. Part Number No
3 ft. Part Number 51150
6 ft. Part Number 52150
A - Root Diameter Minimum [in] 1,355
B [in] 1,75
C [in] 2,12
Company Nook Industries
D - Nominal Rod Diameter [in] 1,5
Dynamic Load Capacity [lb] 11250
E [in] 0,81
End Code for Type 4 [* Journals may show tracings of the thread] 19
End Code for Types 1,2,3,5 [* Journals may show tracings of the thread] 30
F BCD [in] 3,44
F (n) Dia. [in] (4) .397
Flange No-Lash Part Number 73420
Flange Part Number FLG7572
Flange Weight [lb] 3,19
Form 2C
G [in] 0,83
H [in] 4,2
J [In] 1.967-18
Lash (Maximum Axial) [in] 0,009
Nut Weight [lb] 1,28
Screw Code 150-LA
Screw Material 4140 Series
Starts 1
Static Load Capacity [lb] 36000
Thread Code 150
Threads Per Inch 10
Torque to Raise 1 lb. [in-lb] 0,11
Turns Per Inch 10
12 ft. Part Number 53150
Efficiency [%] 15
Part Number 80150
Lead Accuracy In In 0,0003
Lead [in] 0,1
Pitch [in] 0,1
Screw Weight [lb./ft.] 5,47
