Neff Precision Rolled KGS-4040-023-RH-L
Screw only, No Ball nut;Our standard catalog ball screws feature a high luster polished and oiled finish, which provides, smoother operation, and a high quality look and feel.;Additional ball screw coatings (thin dense chrome, black oxide, manganese phosphate) are available as a custom item.;Screws must be machined to fit into end support bearings. Screws can be ordered with ends machined, assembled with ball nuts and/or support bearings.;Please submit a drawing or description for a quotation on a machined screw or screw and nut assembly. Ball Screw Only, Rolled Thread, KGS Style, 40 mm X 40 mm, RH, 23 μm/300mm Lead Accuracy, Steel, 6000 mm Long
Part Number kgs_4040_023_rh_l_8c106_414205
[B] No
Backlash, Max No
Company Thomson Linear
[D1] No
D12 No
D13 No
[D4] No
[D5] No
[D8] No
[D8] No
Flange No
[G] No
[L] No
[L1] No
[L10] No
[L11] No
[L12] No
[L13] No
[L2] No
[L3] No
[L6] No
[L7] No
[L8] No
[L9] No
Load Lock No
Maximum Static Load No
Preload No
Return Style No
Rolled/Ground/Whirled Rolled Thread
Root Dia No
[T] No
[TH] No
Wiper No
Ball Bearing Diameter No
Ball Bearing Quantity No
Diameter Major No
Dynamic Load No
Length 6000 mm
Screw Diameter,Nominal 40 mm
Standard Lead Accuracy ± 23 μm/300mm
Thread Direction RH
Travel Per Shaft Rev 40 mm
