Neff Precision Rolled KGM-N-2005-RH-EE
Nut Only, Screw Sold Separately;Integral wiper included as standard;Available in three preload classes (Type Z1, Z2, Z3) Z1 – light preload to 1-2% Z2 – no preload, clearance held to max indicated in table (standard unless specified) Z3 – no preload, clearance held to max .05mm;Part number KGM-N-2005-RH-EE is sold in North America. This same product is sold in Europe under part number 0215050115 Ball Nut Only, KGM Style, 20 mm X 5 mm, RH, Wiper, 0.08 Max Backlash, Steel, 10.5 kN Dynamic Load
Part Number kgm_n_2005_rh_ee_43f07_6687383
[B] 5 mm
Backlash, Max 0.08 mm
Company Thomson Linear
[D1] 32 mm
D12 No
D13 No
[D4] No
[D5] No
[D8] No
[D8] 3 mm
Flange Not Available
[G] No
[L] No
[L1] No
[L10] 20 mm
[L11] No
[L12] No
[L13] No
[L2] 34 mm
[L3] No
[L6] No
[L7] No
[L8] 7 mm
[L9] 7 mm
Load Lock No
Maximum Static Load 16.6 kN
Preload Optional
Return Style EUS
Rolled/Ground/Whirled No
Root Dia No
[T] 2 mm
[TH] No
Wiper Included
Ball Bearing Diameter 3.5 mm
Ball Bearing Quantity 48
Diameter Major No
Dynamic Load 10.5 kN
Length No
Screw Diameter,Nominal 20 mm
Standard Lead Accuracy ± No
Thread Direction RH
Travel Per Shaft Rev 5 mm
