Neff Precision Rolled KGM-D-6320-RH-EE
Nut Only, Screw Sold Separately;Integral wiper included as standard;Available in three preload classes (Type Z1, Z2, Z3) Z1 – light preload to 1-2% Z2 – no preload, clearance held to max indicated in table (standard unless specified) Z3 – no preload, clearance held to max .05mm;Part number KGM-D-6320-RH-EE is sold in North America. This same product is sold in Europe under part number 0215050297 Ball Nut Only, KGM Style, 63 mm X 20 mm, RH, Wiper, Steel, 65.1 kN Dynamic Load
Part Number kgm_d_6320_rh_ee_fd582_6266472
[B] 6 mm
Backlash, Max No
Company Thomson Linear
[D1] 95 mm
D12 No
D13 No
[D4] No
[D5] No
[D8] No
[D8] 4 mm
Flange Not Available
[G] No
[L] No
[L1] No
[L10] 36 mm
[L11] No
[L12] No
[L13] No
[L2] 82 mm
[L3] No
[L6] No
[L7] No
[L8] 10 mm
[L9] 23 mm
Load Lock No
Maximum Static Load 169.5 kN
Preload Optional
Return Style Channel
Rolled/Ground/Whirled No
Root Dia No
[T] 2.5 mm
[TH] No
Wiper Included
Ball Bearing Diameter No
Ball Bearing Quantity No
Diameter Major No
Dynamic Load 65.1 kN
Length No
Screw Diameter,Nominal 63 mm
Standard Lead Accuracy ± No
Thread Direction RH
Travel Per Shaft Rev 20 mm
