Neff Precision Rolled KGM-D-4010-RH-EE
Nut Only, Screw Sold Separately;Integral wiper included as standard;Available in three preload classes (Type Z1, Z2, Z3) Z1 – light preload to 1-2% Z2 – no preload, clearance held to max indicated in table (standard unless specified) Z3 – no preload, clearance held to max .05mm;Part number KGM-D-4010-RH-EE is sold in North America. This same product is sold in Europe under part number 0215050366 Ball Nut Only, KGM Style, 40 mm X 10 mm, RH, Wiper, 0.08 Max Backlash, Steel, 38.0 kN Dynamic Load
Part Number kgm_d_4010_rh_ee_7c708_5109054
[B] 6 mm
Backlash, Max 0.08 mm
Company Thomson Linear
[D1] 63 mm
D12 No
D13 No
[D4] No
[D5] No
[D8] No
[D8] 4 mm
Flange Not Available
[G] No
[L] No
[L1] No
[L10] 30 mm
[L11] No
[L12] No
[L13] No
[L2] 60 mm
[L3] No
[L6] No
[L7] No
[L8] 10 mm
[L9] 15 mm
Load Lock No
Maximum Static Load 69.1 kN
Preload Optional
Return Style EUS
Rolled/Ground/Whirled No
Root Dia No
[T] 2.5 mm
[TH] No
Wiper Included
Ball Bearing Diameter 7.14 mm
Ball Bearing Quantity 54
Diameter Major No
Dynamic Load 38 kN
Length No
Screw Diameter,Nominal 40 mm
Standard Lead Accuracy ± No
Thread Direction RH
Travel Per Shaft Rev 10 mm
