Neff Precision Rolled KGM-D-1210-RH-00
Nut Only, Screw Sold Separately;Integral wiper included as standard;Available in three preload classes (Type Z1, Z2, Z3) Z1 – light preload to 1-2% Z2 – no preload, clearance held to max indicated in table (standard unless specified) Z3 – no preload, clearance held to max .05mm Ball Nut Only, KGM Style, 12 mm X 10 mm, RH, 0.08 Max Backlash, Steel, 4.9 kN Dynamic Load
Part Number kgm_d_1210_rh_00_cec05_0528598
[B] 3 mm
Backlash, Max 0.08 mm
Company Thomson Linear
[D1] 24 mm
D12 No
D13 No
[D4] No
[D5] No
[D8] No
[D8] 2 mm
Flange Not Available
[G] No
[L] No
[L1] No
[L10] 10 mm
[L11] No
[L12] No
[L13] No
[L2] 27.5 mm
[L3] No
[L6] No
[L7] No
[L8] 7 mm
[L9] 8.75 mm
Load Lock No
Maximum Static Load 8 kN
Preload Optional
Return Style End Cap
Rolled/Ground/Whirled No
Root Dia No
[T] 1.8 mm
[TH] No
Wiper Not available
Ball Bearing Diameter 2 mm
Ball Bearing Quantity No
Diameter Major No
Dynamic Load 4.9 kN
Length No
Screw Diameter,Nominal 12 mm
Standard Lead Accuracy ± No
Thread Direction RH
Travel Per Shaft Rev 10 mm
