Neff Precision Rolled KGF-N-2505-RH-E-EE
Nut Only, Screw Sold Separately;Integral wiper included as standard;Available in three preload classes (Type Z1, Z2, Z3) Z1 – light preload to 1 – 2% Z2 – no preload, clearance held to max indicated in table (standard unless specified) Z3 – no preload, clearance held to max .05mm Ball Nut Only, KGF Style, 25 mm X 5 mm, RH, Flange, 0.08 Max Backlash, Steel, 12.3 kN Dynamic Load
Part Number kgf_n_2505_rh_e_ee_9dc83_77040
[B] No
Backlash, Max 0.08 mm
Company Thomson Linear
[D1] 38 mm
D12 No
D13 No
[D4] 50 mm
[D5] 7 mm
[D8] 62 mm
[D8] No
Flange Included
[G] M6
[L] No
[L1] 8 mm
[L10] 7 mm
[L11] No
[L12] No
[L13] No
[L2] 46 mm
[L3] No
[L6] No
[L7] 14 mm
[L8] No
[L9] 8 mm
Load Lock No
Maximum Static Load 22.5 kN
Preload Optional
Return Style EUS
Rolled/Ground/Whirled No
Root Dia No
[T] No
[TH] No
Wiper No
Ball Bearing Diameter 3.5 mm
Ball Bearing Quantity 63
Diameter Major No
Dynamic Load 12.3 kN
Length No
Screw Diameter,Nominal 25 mm
Standard Lead Accuracy ± No
Thread Direction RH
Travel Per Shaft Rev 5 mm
