Neff Precision Rolled KGF-D-6320-RH-KK
Nut Only, Screw Sold Separately;Integral wiper included as standard;Available in three preload classes (Type Z1, Z2, Z3) Z1 – light preload to 1-2% Z2 – no preload, clearance held to max indicated in table (standard unless specified) Z3 – no preload, clearance held to max .05mm Ball Nut Only, FH Style, 63 mm X 20 mm, RH, Flange, Wiper, 0.08 Max Backlash, 103.1 kN Dynamic Load
Part Number kgf_d_6320_rh_kk_f1a08_3039086
[B] No
Backlash, Max 0.08 mm
Company Thomson Linear
[D1] 95 mm
D12 No
D13 No
[D4] 115 mm
[D5] 13.5 mm
[D8] 135 mm
[D8] No
Flange Included
[G] M8x1
[L] 86 mm
[L1] 18 mm
[L10] 10 mm
[L11] No
[L12] No
[L13] No
[L2] 86 mm
[L3] 24 mm
[L6] 24 mm
[L7] 20 mm
[L8] 100 mm
[L9] 10 mm
Load Lock Included
Maximum Static Load 270.8 kN
Preload Optional
Return Style Deflector
Rolled/Ground/Whirled No
Root Dia No
[T] No
[TH] No
Wiper Included
Ball Bearing Diameter 7.144 mm
Ball Bearing Quantity 186
Diameter Major No
Dynamic Load 103.1 kN
Length No
Screw Diameter,Nominal 63 mm
Standard Lead Accuracy ± No
Thread Direction RH
Travel Per Shaft Rev 20 mm
