Neff Precision Rolled KGF-D-6310-RH-EE
Nut Only, Screw Sold Separately;Integral wiper included as standard;Available in three preload classes (Type Z1, Z2, Z3) Z1 – light preload to 1 – 2% Z2 – no preload, clearance held to max indicated in table (standard unless specified) Z3 – no preload, clearance held to max .05mm;Part number KGF-D-6310-RH-EE is sold in North America. This same product is sold in Europe under part number 0215200086 Ball Nut Only, KGF Style, 63 mm X 10 mm, RH, Flange, Wiper, 0.08 Max Backlash, Steel, 76.0 kN Dynamic Load
Part Number kgf_d_6310_rh_ee_e9d04_4156030
[B] No
Backlash, Max 0.08 mm
Company Thomson Linear
[D1] 90 mm
D12 No
D13 No
[D4] 108 mm
[D5] 11 mm
[D8] 125 mm
[D8] No
Flange Included
[G] M8x1
[L] No
[L1] 16 mm
[L10] 9 mm
[L11] No
[L12] No
[L13] No
[L2] 97 mm
[L3] No
[L6] No
[L7] 18 mm
[L8] 95 mm
[L9] 10 mm
Load Lock No
Maximum Static Load 197 kN
Preload Optional
Return Style EUS
Rolled/Ground/Whirled No
Root Dia No
[T] No
[TH] No
Wiper Included
Ball Bearing Diameter 7.14 mm
Ball Bearing Quantity 140
Diameter Major No
Dynamic Load 76 kN
Length No
Screw Diameter,Nominal 63 mm
Standard Lead Accuracy ± No
Thread Direction RH
Travel Per Shaft Rev 10 mm
