Neff Precision Rolled KGF-D-3232-RH-EE
Nut Only, Screw Sold Separately;Integral wiper included as standard;Available in three preload classes (Type Z1, Z2, Z3) Z1 – light preload to 1 – 2% Z2 – no preload, clearance held to max indicated in table (standard unless specified) Z3 – no preload, clearance held to max .05mm;Part number KGF-D-3232-RH-EE is sold in North America. This same product is sold in Europe under part number 0215200235 Ball Nut Only, KGF Style, 32 mm X 32 mm, RH, Flange, Wiper, 0.15 Max Backlash, Steel, 18.0 kN Dynamic Load
Part Number kgf_d_3232_rh_ee_f7a02_0459483
[B] No
Backlash, Max 0.15 mm
Company Thomson Linear
[D1] 50 mm
D12 No
D13 No
[D4] 65 mm
[D5] 9 mm
[D8] 80 mm
[D8] No
Flange Included
[G] M6
[L] No
[L1] 12 mm
[L10] 6 mm
[L11] No
[L12] No
[L13] No
[L2] 42 mm
[L3] No
[L6] 9 mm
[L7] 12 mm
[L8] 62 mm
[L9] 8 mm
Load Lock No
Maximum Static Load 34.7 kN
Preload Optional
Return Style End Cap
Rolled/Ground/Whirled No
Root Dia No
[T] No
[TH] No
Wiper Included
Ball Bearing Diameter 3.969 mm
Ball Bearing Quantity 124
Diameter Major No
Dynamic Load 18 kN
Length No
Screw Diameter,Nominal 32 mm
Standard Lead Accuracy ± No
Thread Direction RH
Travel Per Shaft Rev 32 mm
