Neff Precision Rolled KGF-D-3220-RH-KK
Nut Only, Screw Sold Separately;Integral wiper included as standard;Available in three preload classes (Type Z1, Z2, Z3) Z1 – light preload to 1-2% Z2 – no preload, clearance held to max indicated in table (standard unless specified) Z3 – no preload, clearance held to max .05mm Ball Nut Only, FH Style, 32 mm X 20 mm, RH, Flange, Wiper, 0.08 Max Backlash, 47.2 kN Dynamic Load
Part Number kgf_d_3220_rh_kk_f7a06_1692270
[B] No
Backlash, Max 0.08 mm
Company Thomson Linear
[D1] 56 mm
D12 No
D13 No
[D4] 71 mm
[D5] 9 mm
[D8] 86 mm
[D8] No
Flange Included
[G] M6x1
[L] 83 mm
[L1] 25 mm
[L10] 6 mm
[L11] No
[L12] No
[L13] No
[L2] 83 mm
[L3] 15 mm
[L6] 15 mm
[L7] 12 mm
[L8] 65 mm
[L9] 9 mm
Load Lock Included
Maximum Static Load 83.2 kN
Preload Optional
Return Style Deflector
Rolled/Ground/Whirled No
Root Dia No
[T] No
[TH] No
Wiper Included
Ball Bearing Diameter 5.556 mm
Ball Bearing Quantity 136
Diameter Major No
Dynamic Load 47.2 kN
Length No
Screw Diameter,Nominal 32 mm
Standard Lead Accuracy ± No
Thread Direction RH
Travel Per Shaft Rev 20 mm
