Neff Precision Rolled KGF-D-3205-RH-KK
Nut Only, Screw Sold Separately;Integral wiper included as standard;Available in three preload classes (Type Z1, Z2, Z3) Z1 – light preload to 1-2% Z2 – no preload, clearance held to max indicated in table (standard unless specified) Z3 – no preload, clearance held to max .05mm Ball Nut Only, FK Style, 32 mm X 5 mm, RH, Flange, Wiper, 0.08 Max Backlash, 19.3 kN Dynamic Load
Part Number kgf_d_3205_rh_kk_efd06_4731521
[B] No
Backlash, Max 0.08 mm
Company Thomson Linear
[D1] 50 mm
D12 No
D13 No
[D4] 65 mm
[D5] 9 mm
[D8] 80 mm
[D8] No
Flange Included
[G] M6x1
[L] 57 mm
[L1] 10 mm
[L10] 6 mm
[L11] No
[L12] No
[L13] No
[L2] 57 mm
[L3] 6 mm
[L6] 6 mm
[L7] 12 mm
[L8] 62 mm
[L9] 8 mm
Load Lock No
Maximum Static Load 36.3 kN
Preload Optional
Return Style Button
Rolled/Ground/Whirled No
Root Dia No
[T] No
[TH] No
Wiper Included
Ball Bearing Diameter 3.5 mm
Ball Bearing Quantity No
Diameter Major No
Dynamic Load 19.3 kN
Length No
Screw Diameter,Nominal 32 mm
Standard Lead Accuracy ± No
Thread Direction RH
Travel Per Shaft Rev 5 mm
