Neff Precision Rolled KGF-D-2550-RH-EE
Nut Only, Screw Sold Separately;Integral wiper included as standard;Available in three preload classes (Type Z1, Z2, Z3) Z1 – light preload to 1 – 2% Z2 – no preload, clearance held to max indicated in table (standard unless specified) Z3 – no preload, clearance held to max .05mm;Part number KGF-D-2550-RH-EE is sold in North America. This same product is sold in Europe under part number 0215200195 Ball Nut Only, KGF Style, 25 mm X 50 mm, RH, Flange, Wiper, 0.15 Max Backlash, Steel, 15.4 kN Dynamic Load
Part Number kgf_d_2550_rh_ee_95f82_3046197
[B] No
Backlash, Max 0.15 mm
Company Thomson Linear
[D1] 40 mm
D12 No
D13 No
[D4] 51 mm
[D5] 6.6 mm
[D8] 62 mm
[D8] No
Flange Included
[G] M6
[L] No
[L1] 10 mm
[L10] 5 mm
[L11] No
[L12] No
[L13] No
[L2] 58 mm
[L3] No
[L6] 10 mm
[L7] 10 mm
[L8] 48 mm
[L9] 8 mm
Load Lock No
Maximum Static Load 31.7 kN
Preload Optional
Return Style End Cap
Rolled/Ground/Whirled No
Root Dia No
[T] No
[TH] No
Wiper Included
Ball Bearing Diameter 3.5 mm
Ball Bearing Quantity 130
Diameter Major No
Dynamic Load 15.4 kN
Length No
Screw Diameter,Nominal 25 mm
Standard Lead Accuracy ± No
Thread Direction RH
Travel Per Shaft Rev 50 mm
