Neff Precision Rolled KGF-D-2525-RH-KK
Nut Only, Screw Sold Separately;Integral wiper included as standard;Available in three preload classes (Type Z1, Z2, Z3) Z1 – light preload to 1-2% Z2 – no preload, clearance held to max indicated in table (standard unless specified) Z3 – no preload, clearance held to max .05mm Ball Nut Only, FH Style, 25 mm X 25 mm, RH, Flange, Wiper, 0.08 Max Backlash, 13.1 kN Dynamic Load
Part Number kgf_d_2525_rh_kk_92109_2949312
[B] No
Backlash, Max 0.08 mm
Company Thomson Linear
[D1] 40 mm
D12 No
D13 No
[D4] 51 mm
[D5] 6.6 mm
[D8] 62 mm
[D8] No
Flange Included
[G] M6x1
[L] 39 mm
[L1] 9 mm
[L10] 5 mm
[L11] No
[L12] No
[L13] No
[L2] 39 mm
[L3] 10 mm
[L6] 10 mm
[L7] 10 mm
[L8] 48 mm
[L9] 8 mm
Load Lock Included
Maximum Static Load 26 kN
Preload Optional
Return Style Deflector
Rolled/Ground/Whirled No
Root Dia No
[T] No
[TH] No
Wiper Included
Ball Bearing Diameter 3.5 mm
Ball Bearing Quantity 120
Diameter Major No
Dynamic Load 13.1 kN
Length No
Screw Diameter,Nominal 25 mm
Standard Lead Accuracy ± No
Thread Direction RH
Travel Per Shaft Rev 25 mm
