Neff Precision Rolled KGF-D-2020-RH-KK
Nut Only, Screw Sold Separately;Integral wiper included as standard;Available in three preload classes (Type Z1, Z2, Z3) Z1 – light preload to 1-2% Z2 – no preload, clearance held to max indicated in table (standard unless specified) Z3 – no preload, clearance held to max .05mm Ball Nut Only, FH Style, 20 mm X 20 mm, RH, Flange, Wiper, 10.8 kN Dynamic Load
Part Number kgf_d_2020_rh_kk_34503_3336385
[B] No
Backlash, Max No
Company Thomson Linear
[D1] 36 mm
D12 No
D13 No
[D4] 47 mm
[D5] 6.6 mm
[D8] 58 mm
[D8] No
Flange Included
[G] M6x1
[L] 36 mm
[L1] 4 mm
[L10] 5 mm
[L11] No
[L12] No
[L13] No
[L2] 36 mm
[L3] 11 mm
[L6] 11 mm
[L7] 10 mm
[L8] 44 mm
[L9] 8 mm
Load Lock Included
Maximum Static Load 17.5 kN
Preload Optional
Return Style Deflector
Rolled/Ground/Whirled No
Root Dia No
[T] No
[TH] No
Wiper Included
Ball Bearing Diameter 3.5 mm
Ball Bearing Quantity 100
Diameter Major No
Dynamic Load 10.8 kN
Length No
Screw Diameter,Nominal 20 mm
Standard Lead Accuracy ± No
Thread Direction RH
Travel Per Shaft Rev 20 mm
