Neff Precision Rolled KGF-D-2005-RH-KK
Nut Only, Screw Sold Separately;Integral wiper included as standard;Available in three preload classes (Type Z1, Z2, Z3) Z1 – light preload to 1-2% Z2 – no preload, clearance held to max indicated in table (standard unless specified) Z3 – no preload, clearance held to max .05mm Ball Nut Only, FK Style, 20 mm X 5 mm, RH, Flange, Wiper, 0.08 Max Backlash, 11.5 kN Dynamic Load
Part Number kgf_d_2005_rh_kk_30686_3366047
[B] No
Backlash, Max 0.08 mm
Company Thomson Linear
[D1] 36 mm
D12 No
D13 No
[D4] 47 mm
[D5] 6.6 mm
[D8] 58 mm
[D8] No
Flange Included
[G] M6x1
[L] 48.5 mm
[L1] 10 mm
[L10] 5 mm
[L11] No
[L12] No
[L13] No
[L2] 48.5 mm
[L3] 5.5 mm
[L6] 5.5 mm
[L7] 10 mm
[L8] 44 mm
[L9] 8 mm
Load Lock No
Maximum Static Load 15.5 kN
Preload Optional
Return Style Button
Rolled/Ground/Whirled No
Root Dia No
[T] No
[TH] No
Wiper Included
Ball Bearing Diameter 3.5 mm
Ball Bearing Quantity No
Diameter Major No
Dynamic Load 11.5 kN
Length No
Screw Diameter,Nominal 20 mm
Standard Lead Accuracy ± No
Thread Direction RH
Travel Per Shaft Rev 5 mm
