Neff Precision Rolled KGF-D-1210-RH-00
Nut Only, Screw Sold Separately;No Wiper, Wiper not available for this size;Available in three preload classes (Type Z1, Z2, Z3) Z1 – light preload to 1 – 2% Z2 – no preload, clearance held to max indicated in table (standard unless specified) Z3 – no preload, clearance held to max .05mm Ball Nut Only, KGF Style, 12 mm X 10 mm, RH, Flange, 0.08 Max Backlash, Steel, 4.9 kN Dynamic Load
Part Number kgf_d_1210_rh_00_cad81_7949460
[B] No
Backlash, Max 0.08 mm
Company Thomson Linear
[D1] 24 mm
D12 No
D13 No
[D4] 32 mm
[D5] 4.5 mm
[D8] 40 mm
[D8] No
Flange Included
[G] M5x0.8
[L] No
[L1] 9.5 mm
[L10] 4 mm
[L11] No
[L12] No
[L13] No
[L2] 27.5 mm
[L3] No
[L6] 5 mm
[L7] 8 mm
[L8] 26 mm
[L9] 6 mm
Load Lock No
Maximum Static Load 8 kN
Preload Optional
Return Style End Cap
Rolled/Ground/Whirled No
Root Dia No
[T] No
[TH] No
Wiper Not available
Ball Bearing Diameter 2 mm
Ball Bearing Quantity No
Diameter Major No
Dynamic Load 4.9 kN
Length No
Screw Diameter,Nominal 12 mm
Standard Lead Accuracy ± No
Thread Direction RH
Travel Per Shaft Rev 10 mm
