Neff Precision Rolled 7832819
Nut Only, Screw Sold Separately;Integral wiper included as standard;Available in three preload classes (Type Z1, Z2, Z3) Z1 – light preload to 1-2% Z2 – no preload, clearance held to max indicated in table (standard unless specified) Z3 – no preload, clearance held to max .05mm;Part number 7832819 is sold in North America. This same product is sold in Europe under part number 0215050335 Ball Nut Only, ZG Style, 50 mm X 10 mm, RH, Wiper, 0.18 Max Backlash, 97.8 kN Dynamic Load
Part Number 7832819_ab509_19002318
[B] No
Backlash, Max 0.18 mm
Company Thomson Linear
[D1] 78 mm
D12 M8x1
D13 6 mm
[D4] No
[D5] No
[D8] No
[D8] No
Flange Sold Seperately
[G] No
[L] 118 mm
[L1] No
[L10] No
[L11] 29 mm
[L12] 13 mm
[L13] 53 mm
[L2] No
[L3] No
[L6] No
[L7] No
[L8] No
[L9] No
Load Lock No
Maximum Static Load 213.2 kN
Preload Optional
Return Style Button
Rolled/Ground/Whirled No
Root Dia No
[T] No
[TH] M72x2.0
Wiper Included
Ball Bearing Diameter 7.144 mm
Ball Bearing Quantity 132
Diameter Major No
Dynamic Load 97.8 kN
Length No
Screw Diameter,Nominal 50 mm
Standard Lead Accuracy ± No
Thread Direction RH
Travel Per Shaft Rev 10 mm
