Neff Precision Rolled 7832771
Nut Only, Screw Sold Separately;Wiper not included (wiper not available on this size);Available in three preload classes (Type Z1, Z2, Z3) Z1 – light preload to 1-2% Z2 – no preload, clearance held to max indicated in table (standard unless specified) Z3 – no preload, clearance held to max .05mm;Part number 7832771 is sold in North America. This same product is sold in Europe under part number 0215050362 Ball Nut Only, ZG Style, 12 mm X 4 mm, RH, 0.07 Max Backlash, 3.5 kN Dynamic Load
Part Number 7832771_c6f06_85768439
[B] No
Backlash, Max 0.07 mm
Company Thomson Linear
[D1] 25 mm
D12 3.0
D13 No
[D4] No
[D5] No
[D8] No
[D8] No
Flange Sold Seperately
[G] No
[L] 34 mm
[L1] No
[L10] No
[L11] 10 mm
[L12] 5 mm
[L13] No
[L2] No
[L3] No
[L6] No
[L7] No
[L8] No
[L9] No
Load Lock No
Maximum Static Load 4 kN
Preload Optional
Return Style Button
Rolled/Ground/Whirled No
Root Dia No
[T] No
[TH] M20x1.0
Wiper Not available
Ball Bearing Diameter 1.984 mm
Ball Bearing Quantity 57
Diameter Major No
Dynamic Load 3.5 kN
Length No
Screw Diameter,Nominal 12 mm
Standard Lead Accuracy ± No
Thread Direction RH
Travel Per Shaft Rev 4 mm
